[postgis-devel] [PostGIS] #740: Something is really messed up with the gserialized or my install of it
PostGIS trac at osgeo.org
Thu Dec 30 08:50:42 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by pramsey):
 If you're missing the operators then something is wrong in your
 build/install/setup, because they are most definitely there.
 The isclosed issue is a real crasher, I will work on that.
 And the third one is also a problem, worthy and worrisome.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/740#comment:1>
