[postgis-devel] [PostGIS] #742: raster should not rely on function names for operators
trac at osgeo.org
Thu Dec 30 09:44:22 PST 2010
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Okay I see why raster is failing on my gserialized install. Nothing wrong
with my install. It is because raster is relying on the actual underlying
function names rather than the operator name and since the non-gserialized
and gserialized have different function names, this poses a problem.
Here are the errors I get when gserialized is enabled.
ERROR: function geometry_overleft(geometry, geometry) does not exist
LINE 3: AS 'select geometry_overleft($1::geometry, $2::geometry)...
Get the same error for geometry_overright, geometry_overright,
geometry_right, geometry_overabove etc.
Note that in gserialized case, the underlying operators are called
geometry_2d_overleft etc.
Seems the solution might be to change raster code to use the operators
instead like
$1::geometry &< $2::geometry
Ticket URL: <http://trac.osgeo.org/postgis/ticket/742>
