[postgis-devel] Feb. Code Sprint and WKTRaster?
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Feb 1 13:56:11 PST 2010
Be careful of not confusing georeference and coordinate system. The georeference is given by 6 float numbers and is only te location of the raster in space. WKT/PROJ.4 definitions refer to coordinate systems which are provided to WKT Raster through the ST_SetSRID function. Both function should be straighforward to implement. There should also be a ST_SetGeoReference(raster, float, float, float, float, float, float) variant.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Mateusz Loskot
>Sent: 1 février 2010 16:10
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] Feb. Code Sprint and WKTRaster?
>David Zwarg wrote:
>> Hello Pierre,
>> I will take a look at the existing regression tests, and try to identify
>> places where tests could be added.
>> Also, I'll take a look at Objective B03a, and see what that entails. I'll
>> ping you when I have more questions.
>Great!
>I would suggest to not to take ST_SetGeoReference(raster, string) first,
>as it may require some more work than it seems.
>Pierre, what is the string actually? Do we expect PostGIS
>compatible WKT/PROJ.4 definitions ow what?
>Best regards,
>Mateusz Loskot, http://mateusz.loskot.net
>Charter Member of OSGeo, http://osgeo.org
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
