[postgis-devel] [PostGIS] #406: DBF only load in shp2pgsql is broken
trac at osgeo.org
Wed Feb 3 14:32:29 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: invalid | Keywords:
Comment (by robe):
Okay this is really mind boggling. This is my exact script that is
failing.
C:\GISData\temp>%PGBIN%\shp2pgsql -a -s 4269 -g the_geom -W "latin1"
tl_2009_110
01_addr.dbf tiger_data.DC_addr > addr.sql
And its failing on creating the geometry index? But I don't have a -I
and yet its adding this to the end
CREATE INDEX "dc_addr_the_geom_gist" ON "tiger_data"."dc_addr" using gist
("the_geom" gist_geometry_ops);
here is that coming from? is there some magical environment variable I am
setting somewhere?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/406#comment:8>
