[postgis-devel] [PostGIS] #409: ST_AsSVG - degraded
trac at osgeo.org
Fri Feb 5 13:13:29 PST 2010
Reporter: sdikiy | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone:
Component: postgis | Version: 1.4.X
Keywords: AsSVG |
(1)[[BR]]
SELECT PostGIS_Full_Version();[[BR]]
"POSTGIS="1.1.6" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS"
select AsText(Intersection('POINT(0 0)'::geometry, 'LINESTRING ( 2 0, 0 2
)'::geometry));[[BR]]
"GEOMETRYCOLLECTION EMPTY"
select AsSVG(Intersection('POINT(0 0)'::geometry, 'LINESTRING ( 2 0, 0 2
(2)[[BR]]
"POSTGIS="1.4.0" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August 2008"
USE_STATS"
select ST_AsText(ST_Intersection('POINT(0 0)'::geometry, 'LINESTRING ( 2
0, 0 2 )'::geometry));[[BR]]
select ST_AsSVG(ST_Intersection('POINT(0 0)'::geometry, 'LINESTRING ( 2 0,
ERROR: invalid memory alloc request size 4294967294[[BR]]
********** Error **********[[BR]]
SQL state: XX000[[BR]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/409>
