[postgis-devel] Has anyone seen this before?
Paragon Corporation
lr at pcorp.us
Fri Feb 5 14:08:36 PST 2010
Further note:
Doing an ST_IsEmpty on one of these monsters shows its not empty.
ST_GeometryType(..) returns ST_Geometry
and when I try to do an ST_Mem_Size on one, I hmm get this
ERROR: lwgeom_size called with unknown-typed serialized geometry
When try ST_IsValid get this
ERROR: Unknown geometry type: 0
I'm going to try to repeat the process of copy from good table to see if the
problem disappears. I suppose it could be disk corruption of some sort.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paragon
Corporation
Sent: Friday, February 05, 2010 4:55 PM
To: 'PostGIS Development Discussion'
Subject: [postgis-devel] Has anyone seen this before?
What would result in an UNKNOWN geometry type. One of our clients is
getting this error when they try to vacuum analyze their table.
> NOTICE: compute_serialized_box3d called on unknown type 0NOTICE:
> compute_serialized_box3d called on unknown type 0 ...
On closer inspection -- I see that there are UNKNOWNs and those UNKNOWNS are
not NULL but the ST_AsText looks blank viewed via psql
select count(*), GeometryType(the_geom) from badtable group by
GeometryType(the_geom); count | geometrytype
98483 | MULTIPOLYGON
1517 | UNKNOWN
This is running on
POSTGIS="1.3.6" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS
PostgreSQL 8.4.1 on x86_64-redhat-linux-gnu, compiled by GCC gcc (GCC) 4.1.2
20
071124 (Red Hat 4.1.2-42), 64-bit
They say the table was created by doing a
create table badtable as select * from goodtable order by addr_num_tlid
limit 100000;
the goodtable doesn't exhibit this bizarre behavior. Not sure if this is a
PostgreSQL bug or PostGIS bug.
Any thoughts?
Thanks,
Regina
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
