[postgis-devel] [PostGIS] #409: ST_AsSVG - degraded
trac at osgeo.org
Fri Feb 5 14:43:10 PST 2010
Reporter: sdikiy | Owner: colivier
Type: defect | Status: new
Priority: critical | Milestone:
Component: postgis | Version: 1.4.X
Resolution: | Keywords: AsSVG
Comment (by colivier):
Paul,
Could you try this patch on your version ?
On my box it's fix this issue, but i did't have the same error message
than yours (i don't get why you have a such high memory allocation)
Index: postgis/lwgeom_svg.c
--- postgis/lwgeom_svg.c (revision 5208)
+++ postgis/lwgeom_svg.c (working copy)
@@ -475,6 +475,8 @@
if ( i ) /* We have some geometries, so add space for delimiters.
size += sizeof(";") * --i;
+ if (size == 0) size++; /* EMPTY GEOMETRYCOLLECTION */
return size;
@@ -486,6 +488,9 @@
LWGEOM_INSPECTED *subinsp;
uchar *subgeom;
+ /* EMPTY GEOMETRYCOLLECTION */
+ if (insp->ngeometries == 0) *ptr = '\0';
for (i=0; i<insp->ngeometries; i++)
if (i) ptr += sprintf(ptr, ";");
Both 1.4 and trunk are impacted
Ticket URL: <http://trac.osgeo.org/postgis/ticket/409#comment:2>
