[postgis-devel] [PostGIS] #409: ST_AsSVG - degraded
trac at osgeo.org
Sat Feb 6 19:12:55 PST 2010
Reporter: sdikiy | Owner: colivier
Type: defect | Status: closed
Priority: critical | Milestone:
Component: postgis | Version: 1.4.X
Resolution: fixed | Keywords: AsSVG
Comment (by robe):
Sdikiy,
As Olivier, noted. Please give the windows experimental 1.4.2SVN a try.
It should have this fix in it.
http://www.postgis.org/download/windows/experimental.php
You should be able to do fine by just replacing your lib/postgis-1.4.dll
with the one packaged in the zip file. Back up your original
postgis-1.4.dll beforehand.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/409#comment:6>
