[postgis-devel] WKTRaster ST_MapAlgebra
George Silva
georger.silva at gmail.com
Tue Feb 9 14:06:19 PST 2010
ArcGIS if I'm not mistaken projects rasters on the fly to do the operations.
George
On Tue, Feb 9, 2010 at 7:29 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> This is a good question…
> I guess users would expect the same kind of result as in any GIS package:
> The pixel values used to compute the mathematical expression SHOULD
> spatially overlap.
> For operations like this in general, PostGIS assume that involved layers
> are in the same coordinate system. There is no such things as automatic on
> the fly layer reprojection. I don’t remember if it warn you if it you
> attempt an operation on two layers projected in two different CS.
> Now what to do when the rasters ovelaps but the pixel sizes are different?
> Or when they have different rotations? What does GRASS does? What does
> ArcGIS does? Whar R does? I would definitely play with those before
> designing anything. We should design the rules involved in this kind of
> function so we can reuse them when we are confronted to similar alignment
> problem in other functions (Intersection(raster, raster)->raster,
> ST_Difference(raster A, raster B)->raster, i.e. most functions taking two or
> more overlapping rasters and returning one raster).
> You also always have to decide what will be the CS, alignment and pixel
> size of the resulting raster. You can impose the ones of one of the raster
> involved (the “master raster”) with an integer parameter specifying the
> index of the “master raster”. You could also supply variant of the function
> allowing to specify these params. Do we want to realign/resample slave
> rasters before doing te operation. This does not seems very efficient but
> maybe there is no other real avenue.
> For sure the challenge is huge. I would maybe start by implementing
> supports for operations on a single raster, delaying problems of alignment
> for later.
> Pierre
> *From:* postgis-devel-bounces at postgis.refractions.net [mailto:
> postgis-devel-bounces at postgis.refractions.net] *On Behalf Of *David Zwarg
> *Sent:* 9 février 2010 15:54
> *To:* PostGIS Development Discussion
> *Subject:* [postgis-devel] WKTRaster ST_MapAlgebra
> Greetings,
> I was reviewing the working spec (
> http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking03), and
> thinking about ST_MapAlgebra:
> *ST_MapAlgebra(raster|geometry, [raster|geometry,…], ‘mathematical
> expression’, ‘raster’ |’geometry’) -> raster/geometry*
> I am considering the following question in the context of using
> ST_MapAlgebra with rasters, and returning a raster. Should this function
> only perform operations on similar rasters? Meaning: do the georeferencing,
> spatial reference, and pixel size have to be the same in all input rasters?
> Thanks,
> Zwarg
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100209/b211c9b3/attachment.html>
