[postgis-devel] Spatial Partitioning Example Suggestion
George Silva
georger.silva at gmail.com
Tue Feb 9 16:44:43 PST 2010
Hello everyone,
After thinking for a while, I'm asking for a opinion on how to develop the
spatial partitioning feature (#181).
I'm coming here after ideas, and I'll be presenting my own.
I made a simple Activity Diagram to illustrate the process. I apologize for
my UML mistakes :P.
The idea, in text is:
Create a partioning_information table (or what other name seems appropriate)
Create a partitions table, with a polygon geometry.
User creates a partioned table. The user inputs: Extent, Width and Height
(of each tile) and an optional Grow Percentage.
After that, the algorithm would create all partition tables (we can think of
a nice naming rule for those tables, or put them into a schema?) and fill
out partition_information and partitions and create the insert/update/delete
rules (or triggers) for that master table.
These rules/triggers would be based on intersection or within, testing the
centroid of each feature against the table grid. I know this can be slow,
but is there any other option? What method is faster to determine if a point
is inside a certain tile?
Tell me what you think.
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100209/8f2ffd4a/attachment.html>
Name: spatial partitions.pdf
Type: application/pdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100209/8f2ffd4a/attachment.pdf>
