[postgis-devel] RFQ: WKT Raster SQL API for being able to intersect vector and raster tables
Paragon Corporation
lr at pcorp.us
Wed Feb 10 09:02:49 PST 2010
Pierre,
Still busy with getting the stack builder ready, but quickly scanning this,
Leo and I had one question.
It might be a stupid question -- so pelase educate us.
Pierre,
On the ST_Intersects(raster,geometry), ST_Intersection(raster,geometry)
Why do you default the band to #1. It would seem useful (or at least we
would assume), that if we don't pass in a band number,
that the function would return true/(vector envelope) if any of the bands
intersect with the geometry. Or is that not of common use or is it just
more computationally intensive?
Thanks,
Regina and Leo
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Pierre
Racine
Sent: Wednesday, February 10, 2010 10:04 AM
To: PostGIS Development Discussion; (postgis-users at postgis.refractions.net)
Subject: Re: [postgis-devel] RFQ: WKT Raster SQL API for being able to
Ok: it should have been "RFC" instead of "RFQ". I don't know what I was
thinking about...
Pierre
>[mailto:postgis-devel- bounces at postgis.refractions.net] On Behalf Of
>Pierre Racine
>Sent: 8 février 2010 13:52
>To: postgis-devel at postgis.refractions.net;
>Subject: [postgis-devel] RFQ: WKT Raster SQL API for being able to
>Hi PostGIS folks,
>Now that you have a little bit of time after the release of PostGIS
>1.5, I would like to request your comments on the WKT Raster
>specifications drawn to meet objective 0.1.6 - "Being able to intersect
>vector and raster to produce vector". In other word: what set of
>function do we need to be able to intersect a geometry layer with a
>raster layer? You will find the last version of the written specs
>here:
>http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWork, STing01#Obj
>ective0.1.6e- Beingabletointersectvectorandrastertoproducevector
>This kind of operation is a generalisation of the operation needed by
>many people doing spatial analysis involving raster and vector. Some
>examples of users expressing their needs for a similar
>functionality:
>http://postgis.refractions.net/pipermail/postgis-users/2009-April/02321
>8.html
>http://postgis.refractions.net/pipermail/postgis-users/2009-March/02289
>0.html
>Some from the r-sig-geo group:
>https://stat.ethz.ch/pipermail/r-sig-geo/2009-December/007177.html
>https://stat.ethz.ch/pipermail/r-sig-geo/2009-November/006999.html
>We plan on reusing as much as possible existing PostGIS functions. The
>basic idea is to convert (only
>the) WKT Raster tiles involved in the intersect to geometries and then
>to procede to a normal vector intersection using the PostGIS
>intersection function. It involves functions like: ST_Envelope(raster),
>ST_ConvexHull(raster), ST_Shape(raster, integer), ST_AsPolygon(raster,
>integer), ST_AsWKTPolygon(raster, integer), ST_Intersects(raster, integer,
geometry), ST_Intersection(raster, integer, geometry). Jorge is in charge of
the implementation.
>We are now in the process of testing if it is worth using the
>polygonize function of GDAL, thus linking with GDAL, or implementing
>our own. A summany of the pros and cons is available at this
>location:
>http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking01#The
>prosandconsofusingGDALvsimpleme
>ntingourownrasterservices
>We are also discussing the pros and cons of directly returning PostGIS
>geometry objects, thus having to link with PostGIS at the C level and
>all it involve in term of release management or to return WKT
>geometries and thus using PostGIS just at the SQL level, facilitating
supports for former/newer PostGIS versions. An argument against linking with
PostGIS is available at this location:
>http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking01#Why
>isitimportnattoavoidlinkingwith
>PostGIS
>The most cited tool to do such operation right now is StarSpan
>(http://starspan.projects.atlas.ca.gov)
>There is plan to implement a raster/raster intersection function as
>well but the exact result of such an operation is still to determine.
>Thanks for your thoughts.
>Pierre
>_______________________________________________
>postgis-devel mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
