[postgis-devel] error when loading postgis template ?
Marc Jansen
jansen at terrestris.de
Thu Feb 11 03:24:31 PST 2010
Hi all,
everybody stand back: I know German :-)
In the mentioned thread the opener reports more errors which could / or
could not be related to the NOTICES:
"Erstelle ich in der DB eine Tabelle mit Geometrietyp, wird in der
Tabelle geometry_columns kein passender Eintrag angelegt."
Means (roughly): If I try to create a table with a column of type
geometry, no row is added to geometry_columns
"Was könnte hier der Fehler sein? Bisher habe ich das Ubuntupaket von
PostGIS verwendet. Jetzt möchte ich aber gerne schon PostGIS 1.5 testen.
Gibt es schon ein Ubuntupaket für die neuste Version von PostGIS?"
Means (roughly): What could be the source of that error? Up until now I
always used the Ubuntu packages of PostGIS, but now I want all the shiny
things they have in 1.5. Is there a Ubuntu-package with 1.5 somewhere?
"Kann man die Funktionsfähigkeit testen?"
Means (roughly): How can I test if everything works as expected in my
install?
Hope that helps.
Regards,
Marc
Paul Ramsey wrote:
> The HINWEIS is a NOTICE, so it's not an error. It's what Regina warned
> about happening; people seeing the notices at the end of the file load
> and flipping out.
> P.
> On Wed, Feb 10, 2010 at 7:09 AM, Nicklas Avén
> <nicklas.aven at jordogskog.no> wrote:
>> Hallo
>> I catched this on a google search.
>> http://www.pg-forum.de/postgis/4197-postgis-1-5-installationsprobleme.html
>> I don't know german. but I understand enough to see that there is a problem
>> with the renaming of st_max_distance to st_maxdistance when loading postgis
>> template.
>> Is the old name still somewhere where it shouldn't be?
>> I can't find it in source more than in changelogs.
>> /Nicklas
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Dipl.-Geogr. Marc Jansen
- Anwendungsentwickler -
terrestris GmbH & Co. KG
Irmintrudisstraße 17
53111 Bonn
Tel: ++49 (0)228 / 96 28 99 -53
Fax: ++49 (0)228 / 96 28 99 -57
Email: jansen at terrestris.de
Web: http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin: terrestris Verwaltungsgesellschaft mbH
vertreten durch: Hinrich Paulsen, Till Adams
