[postgis-devel] [PostGIS] #399: ST_CleanGeometry
trac at osgeo.org
Sat Feb 13 10:53:31 PST 2010
Reporter: strk | Owner: strk
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version:
Resolution: | Keywords:
Comment (by kneufeld):
It does sound like we're talking about requirements and expectations for
different functions.
Paul, I do like your idea of a tolerance. I think this is common use case
- users wanting to remove jitter from their geometries. But how does one
define jitter based on tolerance? Jitter could be removed by running
through Douglas-Peuker, except that it may not be desirable to also
simplify the geometry. So, having something that removes that small loop
or collapsed portion of a polygon is good. This sounds like it could be a
wrapper for Sandro's proposed contract that never drops a vertex - a
function that compares the input and resultant geometries, dropping all of
lower dimension and proportional size.
Sandro, if the functional contract is to never drop a vertex (which I
think is a good idea) *and* never returns a collection, I think you're
right, you'll be returning null an awful lot. Nevertheless, this too
could be a simple sql wrapper function. IF geometrytype(resultant_geom) =
'GEOMETRYCOLLECTION' return null;
Personally, I like the proposed contract. Same dimension, no dropped
vertices, is_valid, (and maybe is_simple) - a function similar to
buffer(0) that deconstructs all input geometries and rebuilds as best as
it can. Non-simple points and lines are made simple, non-valid polygons
are made valid, collections are created where necessary. Wrappers (or
parameters I suppose) can then be used to filter the resultset. My 2
cents.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/399#comment:20>
