[postgis-devel] [PostGIS] #404: Ensure datistemplate is true for template_postgis
trac at osgeo.org
Tue Feb 16 19:05:57 PST 2010
Reporter: pramsey | Owner: robe
Type: task | Status: closed
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: 1.5.X
Resolution: fixed | Keywords: windows
Changes (by robe):
* status: new => closed
* version: trunk => 1.5.X
* resolution: => fixed
Comment:
The logic was in the script. Took us a while to figure out why it wasn't
working. Was exiting at the createlang step so never did the update
template step since the newer versions of PostgreSQL I guess already have
plpgsql installed in the base template.
We also added in packaging of the shp2pgsqlgui loader and a prompt to
overwrite the plugins.ini. It really doesn't do much on PostgreSQL 8.3
since the PgAdmin III packaged with 8.3 doesn't support the plugins
architecture. Please check and see if this makes logical sense to
everyone.
Anyrate if you want to give it a try before we officially upload to
stackbuilder and link on site.
http://www.postgis.org/download/windows/pg84/postgis-pg84-
setup-1.5.0-1.exe
http://www.postgis.org/download/windows/pg83/postgis-pg83-
setup-1.5.0-1.exe
We still plan to test on a couple other machines before we officially
deploy.
Thanks,
Regina and Leo
Ticket URL: <http://trac.osgeo.org/postgis/ticket/404#comment:2>
