[postgis-devel] Call for 1.4.2 and 1.5.1 (Handling of Invalid Geometries)
Paul Ramsey
pramsey at opengeo.org
Wed Feb 17 10:40:13 PST 2010
100% agree. The UTF8 analogy isn't great since we don't have a simple
"cat foo | iconv" fix we can give people, and thereby guarantee that
our databases have full integrity. And a partial fix (we'll autoclose
rings!) leaves us with more complexly invalid data in the database --
so we haven't really fixed the problem. Better to accept invalidity in
all its flavors and provide the tools to identify and work on
improving it inside the database.
P.
On Wed, Feb 17, 2010 at 10:30 AM, Chris Hodgson
<chodgson at refractions.net> wrote:
> strk wrote:
>> I guess we can debate this one.
> I believe this is the crux of the problem:
> 1) Spatial data with various levels of invalidity exists. Whether it comes
> from shapefiles or other formats, whether people paid for it or got it free,
> people have it and they want to use PostGIS with it.
> 2) It is a barrier to entry for those users who have invalid data and want
> to move to using PostGIS, if we cannot accept their invalid data. It may be
> that the data has been working just fine for them in other systems and they
> don't understand or immediately care that anything is wrong with it.
> 3) Some people would like to reduce that barrier to entry by providing a way
> to load the invalid data. There are two ways to do this, clean it before it
> gets in the database, or allow the invalid data in and clean it after it
> gets in.
> 4) There is some minimum level of validity required in order for data to be
> able to properly stored in the database, so there will always be some
> invalid cases which will not be able to be loaded into the database.
> I am personally of the belief that letting invalid stuff into the database
> is a good thing. Even if we can't actually do anything with it in the
> database because it is so invalid, at least it can be stored. Given that it
> is possible for functions to create invalid output, we already know that it
> is possible for invalid stuff to be given to other functions, so we have to
> handle those cases anyway. So we will already be able to output these
> invalid geometries; why not allow them to be input?
> If we agree that PostGIS should provide tools to help clean invalid
> geometries, it seems to make sense for a spatial database to provide these
> tools inside the database, not as external loader-helper tools. This makes
> even more sense given that we may need to clean up invalid geometries that
> are actually created within PostGIS.
> This does mean that we have to accept that even basic calculations such as
> length() and area() will potentially fail - however, the user with invalid
> data must not have the expectation of being able to use these functions, as
> this is a problem inherent with their data. I'd rather tell them "invalid
> goemetry; can't calculate area" than "invalid geometry; can't load into
> database".
> My 2 cents worth.
> Cheers,
> Chris
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
