[postgis-devel] Call for 1.4.2 and 1.5.1 (Handling of Invalid Geometries)
Kevin Neufeld
kneufeld at refractions.net
Wed Feb 17 13:15:54 PST 2010
Interesting. So does this mean that a 2-ordinate polygon would get converted to a LINESTRING and a 3-ordinate polygon
would automatically have a fourth point added, thus closing the ring?
What would these clean to?
'POLYGON((0 0),(1 1 2 2))'
'POLYGON((0 0),(1 1 2 2),(3 3, 4 4, 5 5))'
-- Kevin
On 2/17/2010 1:06 PM, strk wrote:
> On Wed, Feb 17, 2010 at 11:33:22AM -0800, Kevin Neufeld wrote:
>> On 2/17/2010 10:40 AM, Paul Ramsey wrote:
>>> Better to accept invalidity in
>>> all its flavors and provide the tools to identify and work on
>>> improving it inside the database.
>> I'm torn. I totally agree that PostGIS needs to accept invalid geometries
>> for all the reasons Chris and Paul gave. But I'm kinda with Mark on this
>> one - there is a difference between geometry invalidity and what
>> constitutes a geometry in the first place. Shouldn't a POLYGON at least
>> look something like a POLYGON before being allowed into PostGIS? Obviously
>> in this case, it makes most sense to automatically add any missing
>> closing-ring points. But what if the polygon only has one point (ie.
>> 'POLYGON((0 1))')?
> I just committed handling of this by ST_MakeClean:
> # select st_astext(g) as orig,
> st_isvalidreason(g) as invalidity,
> st_astext(st_makevalid(g)) as valid
> from (
> select '0103000000010000000100000000000000000000000000000000000000'::geometry
> as g) as foo;
> -[ RECORD 1 ]-------------------------------------------------------------------
> orig | POLYGON((0 0))
> invalidity | IllegalArgumentException: point array must contain 0 or>1 elements
> valid | POINT(0 0)
> Get these dirty things in, DBs shouldn't be picky.
> We have already st_isvalid() for use to check state !
> --strk;
> () Free GIS& Flash consultant/developer
> /\ http://foo.keybit.net/~strk/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
