[postgis-devel] [PostGIS] #413: ST_Single_Sided_Buffer added
Martin Davis
mbdavis at refractions.net
Fri Feb 19 12:49:28 PST 2010
As I read it, the ArcGIS Buffer method is defined to return only
polygons. This is a different situation than ST_OffsetCurve, which
returns lines.
I think that having the ST_OffsetCurve name is good, to indicate that
the function returns linework. That allows users to conceptualize the
simple rule that ST_Buffer always returns polygonal geometry.
Pierre Racine wrote:
> In ArcGIS they pass one of the four following options:
> {FULL | LEFT | RIGHT | OUTSIDE_ONLY}
> http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Buffer_%28Analysis%29
> Ex.:
> gp.buffer("roads.shp", "buffered_roads.shp", "Distance", "OUTSIDE_ONLY", "ROUND", "LIST", "Road_Type")
> The last two are of no interest for PostGIS. The ROUND is the same as ST_Buffer's endcap. Probably there should be a 4th option to ST_Buffer's buffer_style_parameters to indicate the surface occupied by the buffer:
> 'lineside=full|left|right|outside'
> You probably want to be ablt to do "right|outside" or "left|outside" at the same time.
> Probably, to completely fulfill rafalmag's needs, it would be nice to add "none" as endcap, so we don't get any end cap at all.
> Pierre
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of strk
>> Sent: 19 février 2010 14:42
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] [PostGIS] #413: ST_Single_Sided_Buffer added
>> On Fri, Feb 19, 2010 at 01:52:03AM -0200, George Silva wrote:
>>> I'm sorry to give my 2 cents, but in most softwares everything it's just
>>> called buffer, with different parameters.
>> Could you please provide a full call example of a few of these softwares
>> to obtain what the ST_Single_Sided_Buffer would give ?
>> What it does is giving a linestring offsetted from the original
>> (no area returned).
>> --strk;
>> () Free GIS & Flash consultant/developer
>> /\ http://foo.keybit.net/~strk/services.html
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
