[postgis-devel] [WKTRaster] Setting properties on a raster
David Zwarg
dzwarg at avencia.com
Mon Feb 22 07:38:09 PST 2010
Another thing about properties:
There is no ST_GeoReference method (currently), which is in the 0.1.6d
spec. However, there is an ST_gdalgeotransform and an
ST_esriworldfile method. Are these alternate/vendor specific
implementations, and ST_GeoReference is just eerily similar, or should
one of them be renamed? I was also thinking about writing the setter,
but wanted to make sure I wasn't stepping on ML's toes -- the task is
assigned to him on the planning page.
Thanks,
Zwarg
On Sun, Feb 21, 2010 at 2:37 PM, David Zwarg <dzwarg at avencia.com> wrote:
> Sounds good to me, I'll change the spec.
> z
> On Sun, Feb 21, 2010 at 2:26 PM, Pierre Racine
> <Pierre.Racine at sbf.ulaval.ca> wrote:
>>>I'm looking at setting the properties of a raster. I managed to
>>>figure out how to set the SRID pretty easily:
>>>http://trac.osgeo.org/postgis/ticket/423
>> This is very great Zwarg!
>>>I'm thinking about ST_SetPixelType now, and I'm wondering how you want
>>>to handle the data conversions. It seems like when the pixel type is
>>>changed, the raster data will need to be processed and either
>>>truncated or re-allocated, as the pixel type is changed. Is that
>>>correct?
>>>A also noticed that ST_SetWidth and ST_SetHeight are not in the spec,
>>>is that intentional? Would it ever make sense to set the height and
>>>the width? In one sense, ST_SetPixelType is performing the same kind
>>>of truncation/expansion on the bit depth as ST_SetWidth/ST_SetHeight
>>>would perform the truncation/expansion in the spatial dimension.
>>>Should ST_SetPixelType be dropped if ST_SetWidth and ST_SetHeight are
>>>not implemented? Or should ST_SetHeight and ST_SetWidth be
>>>implemented as well?
>> I agree that ST_SetPixelType does not really make sence... If I want to change the pixel type I would probably instead want to do something like:
>> ST_MapAlgebra(raster, 'int(A)') on a float raster or ST_MapAlgebra(raster, 'float(A)') on a integer raster...
>> Pierre
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
