[postgis-devel] [PostGIS] #440: [wktraster] Consolidate st_gdalgeotransform and st_esriworldfile into st_georeference
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Mon Feb 22 12:32:16 PST 2010
Maybe we should agree on changes in the specs in the forum before polluting Trac too much.
Otherwise I agree with this change. The default should be 'GDAL' if no second parameter is passed.
Is it really faster to implement such a function in C instead of plPgSQL? I know one is implemented in C and the other one in plPgSQL.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of PostGIS
>Sent: 22 février 2010 15:16
>Cc: postgis-devel at postgis.refractions.net
>Subject: [postgis-devel] [PostGIS] #440: [wktraster] Consolidate st_gdalgeotransform and
>st_georeference
> Reporter: dzwarg | Owner: dzwarg
> Type: task | Status: new
> Priority: medium | Milestone: WKTRaster 0.1.6
>Component: wktraster | Version: trunk
> Keywords: |
> Consolidate the georeference get methods into a single get method, with 1
> parameter that switches between GDAL and ESRI output.
> * ST_GeoReference(raster, 'ESRI'|'GDAL') -> string
> See [wiki:WKTRaster/SpecificationWorking01#Objective0.1.6d-
> BeingabletogetallthepropertiesofarasteralltheGetfunctions
> SpecificationWorking01]
>Ticket URL: <http://trac.osgeo.org/postgis/ticket/440>
>PostGIS <http://trac.osgeo.org/postgis/>
>The PostGIS Trac is used for bug, enhancement & task tracking, a user and developer wiki, and a
>view into the subversion code repository of PostGIS project.
>_______________________________________________
>postgis-devel mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
