[postgis-devel] [WKTRaster] Setting properties on a raster
Mateusz Loskot
Mateusz.Loskot at cadcorp.com
Tue Feb 23 07:16:34 PST 2010
Pierre Racine wrote:
> David Zwarg wrote:
> >There is no ST_GeoReference method (currently), which is in the 0.1.6d
> >spec. However, there is an ST_gdalgeotransform and an
> >ST_esriworldfile method. Are these alternate/vendor specific
> >implementations, and ST_GeoReference is just eerily similar, or should
> >one of them be renamed? I was also thinking about writing the setter,
> >but wanted to make sure I wasn't stepping on ML's toes -- the task is
> >assigned to him on the planning page.
> ST_esriworldfile() and ST_gdalgeotransform() are replacement for
> ST_GeoReference().
> There should probably be two different setters: one the ESRI way, one
> the GDAL way. The difference between the two is only that one uses the
> upper left CORNER and the other one the upper left CENTER.
Pierre,
Yesterday during talk with David, I suggested to refactor the two functions
ST_esriworldfile() and ST_gdalgeotransform() back to single function
ST_GeoReference and control output with parameters. I didn't mean to
apply this idea straight away, but to go through spec-level first, of course.
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
This email is confidential and may be privileged and should not be used, read
or copied by anyone who is not the original intended recipient. If you have
received this email in error please inform the sender and delete it from
your mailbox or any other storage mechanism. Unless specifically stated,
nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
warrant that any information contained in this email is accurate.
Cadcorp cannot accept liability for any statements made which are clearly the
sender's own and not expressly made on behalf of Cadcorp or one of its agents.
Please rely on your own virus check. No responsibility is taken by Cadcorp
for any damage arising out of any bug or virus infection.
