[postgis-devel] ST_ShiftLongitude
strk
strk at keybit.net
Tue Feb 23 07:29:27 PST 2010
Another thing...
for very good results the "cut" operation should
really ST_SplitGeometry and "glue" operation should
ST_Union.
If we ST_Union w/out ST_Split we'll loose symmetricity
so I'd avoid that for the moment. One can always
ST_Union manually later..
--strk;
On Tue, Feb 23, 2010 at 04:25:31PM +0100, strk wrote:
> On Tue, Feb 23, 2010 at 03:08:05PM +0100, strk wrote:
> > So, what I think should be paremetrized is:
> > 1: X-value for where to cut (longitude)
> > 2: Side to move (left to right or right to left)
> > 3: range of the whole block
> > (minx if moving right to left, maxx if moving left to right)
> I'm thinking the parameter could be reduced to 2:
> 1: X-value representing the cut-line
> 2: shift amount
> If shift amount is negative we're moving left
> if it's positive we're moving right.
> The function should check component geometries of a feature
> to fall *completely* on the left (moving right) or right (moving left)
> of the given X-value and only move those. Doing so will avoid introducing
> invalid geometries.
> The function would not be symmetric anymore.
> Going from -180..180 to 0..360 would be done with:
> ST_ShiftLongitude(the_geom, 0, +360)
> Going from 0..360 to -180..180 would be done with:
> ST_ShiftLongitude(the_geom, 180, -360)
> How do you like it ?
> If we want to keep the same function (would be easier) this
> would mean taking no args as a default of 0, +360 and loosing
> the current symmetricity (which again is not documented).
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://foo.keybit.net/~strk/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
