[postgis-devel] [PostGIS] #450: ST_Area(geography) returns wrong result for objects crossing dateline
trac at osgeo.org
Thu Feb 25 05:35:20 PST 2010
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 1.5.1
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Old description:
> http://postgis.refractions.net/pipermail/postgis-users/2010-
> February/025984.html
> A box that doesn't cross the dateline returns a good result:
> g4wd=# select st_area(g)/1000000, st_area(transform(geometry(g), 4326)),
> astext(geometry(g)) from (select 'POLYGON((178.5 2, 178.5 1, 179.5 1,
> 179.5
> 2, 178.5 2))'::geography) as foo(g);
> ?column? | st_area | astext
> 12304.814950073 | 1 | POLYGON((178.5 2,178.5 1,179.5 1,179.5
> 2,178.5
> 2))
> (1 row)
> But the same box s
> hifted over the dateline returns a bad result.
> {{{g4wd=# select st_area(g)/1000000, st_area(transform(geometry(g),
> 4326)),
> astext(geometry(g)) from (select 'POLYGON((179.5 2, 179.5 1, -179.5 1,
> -179.5 2, 179.5 2))'::geography) as foo(g);
> 55910.8880691158 | 359 | POLYGON((179.5 2,179.5 1,-179.5 1,-179.5
> 2,179.5 2))
> (1 row)
New description:
179.5
2,178.5
2))
(1 row)
But the same box s
2,179.5 2))
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/450#comment:1>
