[postgis-devel] New make garden rule
strk
strk at keybit.net
Sat Feb 27 07:08:22 PST 2010
On Sat, Feb 27, 2010 at 01:40:35PM +0100, Olivier Courtin wrote:
> On Feb 27, 2010, at 1:00 PM, strk wrote:
> >On Fri, Feb 26, 2010 at 04:09:27PM +0100, Olivier Courtin wrote:
> >>I've add a new 'make garden' rule in main Makefile.
> >>It launch full Garden Test regression process.
> >Sorry for my ignorance, but what is a Garden Test ?
> It's the regression tests writted by Regina, and based upon
> PostGIS documentation functions prototypes.
> http://trac.osgeo.org/postgis/wiki/DevWikiGardenTest
> It's usefull to see if Postgis just don't crash on some functions
> with peculiar geometry input.
> Or if some functions returns unwanted lwerror...
Neat, I'm gonna love it!
What's the recomended way to check if an error occurred ?
I got not "failure" notice but saw lots of "aborted transaction"
messages flying by. Things like:
ERROR: function st_point(numeric, integer) does not exist
LINE 2: FROM ((SELECT ST_SetSRID(ST_Point(i,j),4326) As the_geom
As long as the script tries to use documented calls this sounds
like a failure to me...
Results report (found but not properly advertised by 'make garden')
is here (volatile): http://foo.keybit.net/~strk/tmp/garden_result.txt.gz
Not sure it also contains stderr.
--strk;
() Free GIS & Flash consultant/developer
/\ http://foo.keybit.net/~strk/services.html
