[postgis-devel] [PostGIS] #369: shp2pg-gui the geometry column setting not sticking
trac at osgeo.org
Sun Jan 3 14:44:46 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by pramsey):
This is by design. The default "geometry column" is "the_geom" and the
default "geography column" is "geog". The logic is set up such that, if
you open Options, then change the load type to geography, the default
column name will reflect the load type. How do I know if you have a column
name that is the default? I compare it. So, because you have "geog" (the
default geography column) in your entry, but you are loading geometry, I
assume "oh, she's using defaults" and I change it to the default geometry
column name. If you use any other name than "geog", you'll find that the
value is perfectly sticky. You'll also find that if you don't touch the
name, and go into the Options menu and select a geography load, the name
will automatically change to "geog", which is what we want.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/369#comment:1>
