[postgis-devel] [PostGIS] #373: Documentation syntax error in hard upgrade
PostGIS trac at osgeo.org
Wed Jan 6 05:18:01 PST 2010
 Reporter:  psvensso       |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 1.4.1
Component:  postgis        |     Version:  1.4.X
 Keywords:  documentation  |
 The instruction in "2.7.2 Hard upgrade" - last sentence on how to empty
 and load updated spatial_ref_sys.sql  gives syntax error (in postgresql
 8.4.x)
 -> You may use truncate to empty the table instead of drop
 When using "drop"
 newdb=# drop spatial_ref_sys;
 ERROR:  syntax error at or near "spatial_ref_sys"
 LINE 1: drop spatial_ref_sys;
 when using "truncate"
 newdb=# truncate spatial_ref_sys;
 TRUNCATE TABLE
 newdb=# \i /usr/share/contrib/spatial_ref_sys.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/373>
