[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
trac at osgeo.org
Sat Jan 9 11:01:46 PST 2010
Reporter: pramsey | Owner: mcayland
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Actually that problem went away second time around when I compiled --with-
gui for my 8.3 install so you are probably right it might be a path thing
since this is the box I have 8.2,8.3, and 8.4 installed on and maybe the
changes in gui flipped path.
But for my 8.3 install (which is the one I had tried earlier), it does not
install the postgis-1.5.dll, but for my 8.4 install everything works
perfectly.
Nicklas are you compiling for 8.3 or 8.4?
I'll give 8.3 another try.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:25>
