[postgis-devel] two questions about UsersWikiWinCompile
Nicklas Avén nicklas.aven at jordogskog.no
Sun Jan 10 09:09:16 PST 2010
You are right Regina. It works for me too both with and without "./" . Little strange, I am sure it didn't work a while ago, but probably I was just doing it wrong. Result: I will not change anything :-) /Nicklas
2010-01-09 Paragon Corporation wrote:
>Yah I set the prefix to a different location so can test different versions of libxml.  Since its statically compiled into the postgis-1.5.dll anyway, it doesn't need to go into postgres folder.> >./configure works fine for me under MingW though.  It doesn't work for you.  I think both configure and ./configure work fine for me so I'm indifferent if you want to change it.> >Thanks,>Regina
>>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Nicklas Avén
>Sent: Saturday, January 09, 2010 2:36 PM
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] two questions about UsersWikiWinCompile
 Ok, I think I maybe see the answer to the first question myself. > >It was a new approach to it in version 113 of the document. I guess it works just as good.> >/Nicklas
>2010-01-09 Nicklas Avén wrote:
I was just trying to compile libxml to be able to test 1.5 aginst 8.3.> >
Then in UsersWikiWinCompile is it really right the line :> >
./configure --prefix=/c/thesrc/libxml/libxml2-2.7.6release --disable-shared CCFLAGS=LDFLAGS="-Wl,-static" CFLAGS=-O2
shouldn't libxml be installed in the postgresinstallation?> >
and if so, should --prefix point to bin-folder or ?> >
next question> >
why are we writing ./configure everywhere. Yes, I know, probably I started it, but to me it douesn't work in MinGW. I have to write just configure without "./"> >
Just wanted to check before I do any changes> >
/Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100110/6e360135/attachment.html>
