[postgis-devel] [PostGIS] #381: Add an optional parameter to ST_Scale to specify the anchor point
trac at osgeo.org
Mon Jan 11 13:12:42 PST 2010
Reporter: kneufeld | Owner: pramsey
Type: enhancement | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
ST_Scale is a simple wrapper around ST_Affine, but it's missing a very
common "scale about the midpoint or lower left" option.
IE. simply scaling about the midpoint of a geometry is currently a
complicated two step approach:
SELECT
ST_AsText(
ST_Translate(
ST_Scale(geom, 3, 2),
-3 * (ST_Xmin(geom)+ST_XMax(geom))/2 +
((ST_Xmin(geom)+ST_XMax(geom))/2),
-2 * (ST_Ymin(geom)+ST_YMax(geom))/2 +
((ST_Ymin(geom)+ST_YMax(geom))/2)
FROM
(SELECT 'POLYGON (( 2 5, 2 6, 3 6, 3 5, 2 5 ))'::geometry AS geom) a;
st_astext
POLYGON((1 4.5,1 6.5,4 6.5,4 4.5,1 4.5))
(1 row)
I recommend a new optional char(2) parameter be added to ST_Scale that
will permit a user to scale based on various common anchor points:
'SW' | 'BL' - south west (bottom left) corner[[BR]]
'NE' | 'TR' - north east (top right) corner[[BR]]
...[[BR]]
'MP' | 'C' - midpoint (centre) of the geometry[[BR]]
All the complicated xmin/ymin translation stuff could then be
automatically computed and placed in xoffset/yoffset parameters of
ST_Affine.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/381>
