[postgis-devel] PostGIS 1.5 regression with GEOS 3.0.3
Paragon Corporation
lr at pcorp.us
Tue Jan 12 05:57:22 PST 2010
+1. I'd be really happy if you bumped it to 3.2. Like I said I hate the
fact that some of the functions we have will not work on lower versions we
claim to support. I don't think its anything most people coming new to
PostGIS (or not highly familiar with it) will understand and just causes
confusion.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Tuesday, January 12, 2010 5:59 AM
To: PostGIS Development Discussion
Subject: [postgis-devel] PostGIS 1.5 regression with GEOS 3.0.3
Hi folks,
I'm seeing the following regression with GEOS 3.0.3 with SVN trunk, but not
with GEOS 3.1.1 or 3.2.0:
*** tickets_expected Tue Jan 12 10:10:00 2010
--- /tmp/pgis_reg_7461/test_45_out Tue Jan 12 10:38:45 2010
*** 1,4 ****
! #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
#11|0
#21|SRID=31293;POINTM(6220.13 5337367.145 4566)
t
--- 1,4 ----
! #2|POLYGON((2 2,3 2,3 1,2 1,1 1,1 2,2 2))
#11|0
t
The SQL that produces this appears to be:
SELECT '#2', ST_AsText(ST_Union(g)) FROM ( VALUES
('SRID=4326;MULTIPOLYGON(((1 1,1 2,2 2,2 1,1 1)))'),
('SRID=4326;MULTIPOLYGON(((2 1,3 1,3 2,2 2,2 1)))')
) AS v(g);
This looks like it is just the order that has changed rather than the actual
result. Should we consider bumping the minimum GEOS version to
3.1 for PostGIS 1.5 just to help keep things clean? As a plus, we get to
remove lots more #ifdef cruft...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
Corporation plc - control through freedom http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
