[postgis-devel] PostGIS 1.5 beta2
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jan 14 16:54:15 PST 2010
Hum, no error here for me. Hooray for platform differences.
P
On Thu, Jan 14, 2010 at 3:38 PM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> +1. 'make check' does give me one error though ...
> regress_proj. ok
> dumppoints. ok
> wmsservers. ok
> tickets. failed (diff expected obtained: /tmp/pgis_reg_1623/test_45_diff)
> regress_ogc_cover. ok
> regress_ogc_prep. ok
> Run tests: 47
> Failed: 1
> make[1]: Leaving directory `/var/home/buildbot/workspace/src/regress'
> cat /tmp/pgis_reg_1623/test_45_diff
> *** tickets_expected Thu Jan 14 14:59:08 2010
> --- /tmp/pgis_reg_1623/test_45_out Thu Jan 14 15:01:16 2010
> *** 1,10 ****
> #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
> ! #11|0
> #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
> t
> ERROR: AddGeometryColumns() - invalid SRID
> #44|t|t
> ! #58|POLYGON((220187.382089758 150406.434743975,220187.382089758
> 150506.717070259,220288.81590723 150506.717070259,220288.81590723
> 150406.434743975,220187.382089758 150406.434743975))
> ERROR: geometry_to_gml2: 'CurvePolygon' geometry type not supported
> #66|CIRCULARSTRING(0 0,1 1,2 2)
> #68a|MULTIPOINT(1 3,4 5)
> --- 1,10 ----
> ! #11|0.889477943128855
> t
> #44|t|t
> ! #58|POLYGON((220187.382089667 150406.434743975,220187.382089667
> 150506.71707029,220288.815907205 150506.71707029,220288.815907205
> 150406.434743975,220187.382089667 150406.434743975))
> -- Kevin
> Paragon Corporation wrote:
>> +1 (make check still doesn't work for me, but I'd still like a beta 2)
>> Thanks,
>> Regina
>> ________________________________________
>> From: postgis-devel-bounces at postgis.refractions.net
>> [postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>> [pramsey at opengeo.org]
>> Sent: Thursday, January 14, 2010 3:29 PM
>> To: PostGIS Development Discussion
>> Subject: [postgis-devel] PostGIS 1.5 beta2
>> Call for votes on releasing beta2, now that the install process seems to
>> be
>> fixed up.
>> +1 !
>> P
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure pursuant to
>> Massachusetts law. It is intended solely for the addressee. If you
>> received
>> this in error, please contact the sender and delete the material from any
>> computer.
