[postgis-devel] PostGIS 1.5 beta2
Nicklas Avén
nicklas.aven at jordogskog.no
Fri Jan 15 02:37:41 PST 2010
Ok, so this folder 00-regress-install should be created temporary, work as install directory and then deleted afterwards?
/Nicklas
2010-01-15 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> I had this error yestarday in the log-file not in the terminal:
>> psql:postgis.sql:56: ERROR: could not access file
>> "/c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5": No such
>> file or directory
>> I have never noticed this /00-regress-install/lib
>> -path before, and I don't fysically see it. What is that. I see you have
>> it too.
>> /Nicklas
>00-regress-install is just a dummy path for the out of place regression
>tests. The way it works with 1.5 is that "make check" now effectively
>does a "make install" with the path overridden to
>regress/00-regress-install for the base of the PostgreSQL installation.
>The 'sed' command then rewrites the paths in postgis.sql to point to
>this new temporary installation before loading it into the regression
>database.
>HTH,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100115/5552af75/attachment.html>
