[postgis-devel] PostGIS 1.5 beta2
Nicklas Avén nicklas.aven at jordogskog.no
Fri Jan 15 03:23:28 PST 2010
Mark  You were right that there was a permission problem for me. I gave my postgres user permissions on regress-folder and then 00-regress-install  was created. But I still get: psql:postgis.sql:56: ERROR:  could not access file "/c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5": No such file or directory in log-file. in the folder regress/00-regress-install/lib/ the is the postgis-1.5.dll file. Is there a problem it doesn't use the dll-extension? I says it can't find postgis-1.5 istead of postgis-1.5.dll.  What is giving the right exrension to the right platform? The dll file has inhereted the permissions from regress-folder as you said. /Nicklas
2010-01-15 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> Ok, so this folder 00-regress-install should be created temporary, work
>> as install directory and then deleted afterwards?
>> /Nicklas
>Yes, it's only created for the duration of the regression tests. But it
>must be readable by the backend (postgres) user.
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100115/a0d47d7d/attachment.html>
