[postgis-devel] PostGIS 1.5 regression with GEOS 3.0.3
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Fri Jan 15 07:41:13 PST 2010
Paragon Corporation wrote:
> I see it as
> 3.0 - has known bugs
> 3.1 - works well, but can leak memory, has more topological exceptions,
> doesn't support all PostGIS 1.5 function (some will be disabled IFDEF
> madness)
> 3.2 - (hopefully) works well with no memory leaks
> Not that it matters though.
> Thanks,
> Regina
Do you really find that 3.1 is worse than 3.0 for topological
exceptions? Wow, I'm obviously not stressing it enough...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
