[postgis-devel] [PostGIS] #318: 900913->4326 Transform
trac at osgeo.org
Sun Jan 17 12:01:38 PST 2010
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.4.1
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by arthurnederlof):
Hallo,
a more trivial example (osm form open street map, worldcountries has
geometries in 4326 srid format:
this works:
select world.gid, osm.admin_level from planet_osm_polygon as
osm,worldcountries as world where (osm.admin_level='4') AND
(ST_Contains(ST_Transform(world.the_geom,900913),ST_Centroid(osm.way)))
limit 10
this one does not work:
(ST_Contains(world.the_geom,ST_Centroid(ST_Transform(osm.way,4326))))
limit 10
ERROR: transform: couldn't project point (5.1755e+06 6.1799e+06 0):
failed to load NAD27-83 correction file (-38)
HINT: PostGIS was unable to transform the point because either no grid
shift files were found, or the point does not lie within the range for
which the grid shift is defined. Refer to the ST_Transform() section of
the PostGIS manual for details on how to configure PostGIS to alter this
behaviour.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:11>
