[postgis-devel] [PostGIS] #318: 900913->4326 Transform
trac at osgeo.org
Tue Jan 19 06:11:13 PST 2010
Reporter: pramsey | Owner: mcayland
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.4.1
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Guys,
I can produce this error on my PostGIS 1.5SVN windows install
SELECT
ST_ASTEXT(ST_Transform(ST_SetSRID(ST_Point(-305748.113141,7834489.65112),900913),4267));
Yields:
couldn't project point (-305748 7.83449e+006 0): failed to load NAD27-83
correction file (-38)
HINT: PostGIS was unable to transform the point because either no grid
shift files were found, or the point does not lie within the range for
which the grid shift is defined. Refer to the ST_Transform() section of
the PostGIS manual for details on how to configure PostGIS to alter this
behaviour.
This could possibly be the same problem we ran across in #387 that the
proj4text is simply different, or possibly I'm using an out of date set of
datum shift files.
I tried my 1.3.6 install, and that doesn't even have this entry. It is my
understanding that this is a defunct srid put in a while ago before there
was an official google mercator EPSG SRID, so its highly likely everyones
is slightly different unless they reloaded their spatial_ref_sys.
Mine reads:
SELECT proj4text from spatial_ref_sys where srid = 900913;
+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+units=m +k=1.0 +nadgrids=@null +no_defs
and I'm running proj 4.6.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:14>
