[postgis-devel] [PostGIS] #318: 900913->4326 Transform
PostGIS trac at osgeo.org
Tue Jan 19 10:35:08 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.4.1
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by filbertkm):
 I had the same problem.  I upgraded from PostGIS 1.3.6 to the 1.5 svn
 version.  I used spatial_ref_sys and the postgis upgrade script.  I also
 used a 900913.sql script of my own (can't remember where I got it).
 Since PostGIS 1.3.6, the Google Spherical Mercator projection has been
 assigned an EPSG code:
 http://spatialreference.org/ref/epsg/3785/
 My database still had all the tables assigned as 900913.  To resolve the
 problem, I dropped the 900913 entry from my spatial_ref_sys table:
 Then I took the PostGIS spatial_ref_sys INSERT statement for 3785 from the
 spatial reference site.  I updated my 900913.sql statement with this one,
 but changing the srid and auth_srid to 900913.  I then readded 900913 to
 PostGIS and everything works great now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/318#comment:16>
