[postgis-devel] PostGIS 1.5 beta2
Nicklas Avén
nicklas.aven at jordogskog.no
Wed Jan 20 12:28:58 PST 2010
Ok, it seems to work :-) new patch attached But it didn't work at first, and I don't know what I changed ( I downloaded fresh config.ac and regress/makefile.in) But it works to me now /Nicklas
2010-01-20 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> Mark
>> After a lot of trial and error I have a patch that works for me in MingW :-)
>> first I tried to pass "pwd -W" as is, to makefile.in and let it make
>> the path from there. I thought that was what you meant. But I didn't
>> success so in the patch the path is made earlier so PWDREGRESS holds the
>> path in itself instead of pwd-W
>> Is that ok?
>> If someone wants to try it:
>> you have to run autogen.sh after applying the patch.
>> /Nicklas
>I don't think we should make use of $(pwd) in this way, since as
>implemented by your patch then PWDREGRESS is evaluated to the current
>path at configure time, rather than at runtime which I suspect will
>cause some confusion further down the line.
>The configure.ac part is mostly correct, but I would expect it to look
>like this, as per the original version:
>dnl
>dnl MingW requires use of pwd -W to give proper Windows (not MingW) paths
>dnl for in-place regression tests
>dnl
>case $host_os in
> *mingw*)
> PWDREGRESS="pwd -W"
> PWDREGRESS="pwd"
>esac
>AC_DEFINE_UNQUOTED([PWDREGRESS])
>AC_SUBST([PWDREGRESS])
>After this, the changes to regress/Makefile.in should then be reasonably
>simple, e.g.:
># Where we put our regression installation
>srcdir=$(shell @PWDREGRESS@)
>REGRESS_INSTALLDIR=$(srcdir)/00-regress-install
>HTH,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100120/869a794c/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100120/869a794c/attachment.obj>
