[postgis-devel] Cunit and lwerror
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Jan 25 08:10:58 PST 2010
Olivier Courtin wrote:
> That's a good suggestion !
> I tryed something in this way (patch attached), but still meet 2 problems:
> 1) Common usage with lwerror is to call them directly (i.e without a
> return as
> prefix), so i never been able to catch the error message in the
> cunit test itself
> 2) If i suppress the exit instruction in lwerror handler, i introduce
> possible
> (huge) side effect...
I think that the current design expects lwerror to abort which I guess
means that we leak memory within a particular test executable. I don't
think this should be a problem in the short term, unless someone
repeatedly calls lwerror during regression lots of times with something
that takes lots of memory. Try it and see ;)
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
