[postgis-devel] Adding spec file to postgis SVN
Devrim GÜNDÜZ
devrim at gunduz.org
Tue Jan 26 03:08:03 PST 2010
On Tue, 2010-01-26 at 10:47 +0000, Mark Cave-Ayland wrote:
> If placing the .spec file under trunk/rpm is the standard location,
> then I see no reason not to stick to it. Similarly, I wouldn't be
> opposed to having a debian/ directory under trunk if it were
> requested. Given that there is a manpower cost to creating packages
> for a release, I think we should do everything we can to help
> downstream packagers.
GIS related packages are most requested packages from our repository,
that's why I'd like to add new spec to postgis...
Devrim GÜNDÜZ, RHCE
Command Prompt - http://www.CommandPrompt.com
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100126/5c3afa82/attachment.sig>
