[postgis-devel] Proposing 1.5.0
Paragon Corporation
lr at pcorp.us
Wed Jan 27 04:31:21 PST 2010
Will test win32 later today, however I think we concluded the win32 was
fine. That issue that came up was because the 1.4+ spatial_ref_sys.sql was
wrong and Paul fixed that.
Is that what you are referring to Mark?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, January 27, 2010 7:11 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Proposing 1.5.0
Paul Ramsey wrote:
> I have placed a tarball for testing here:
> http://dl.dropbox.com/u/1184727/postgis-1.5.0.tar.gz
> I am going to test on Solaris then come back with my vote for approval.
> P
All regression tests pass for me:
PostgreSQL 8.3.7 on x86_64-unknown-linux-gnu, compiled by GCC gcc (Debian
4.3.2-1.1) 4.3.2
Postgis 1.5.0 - 2010-01-27 11:38:03
GEOS: 3.2.0-CAPI-1.6.0
PROJ: Rel. 4.6.1, 21 August 2008
However: we still need to fix the PROJ.4 grid shift file path in
lwgeom_transform.c::SetProj4LibPath() so that the path under contrib/ now
contains the version number. See attached proposed patch.
We also need to get Leo/Regina to verify that the Win32 installer is
dropping copies of the PROJ.4 data files in the correct place.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
