[postgis-devel] [PostGIS] #395: Make check errors on Mac - spheroid area - srid 32702
PostGIS trac at osgeo.org
Thu Jan 28 07:03:00 PST 2010
  Reporter:  colivier  |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  medium    |   Milestone:  PostGIS 1.5.0
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:  Mac regress  spheroid_area 32702
Comment (by mcayland):
 Hmmm I think looking at regress/run_test that it doesn't actually load
 spatial_ref_sys.sql during a regression run. Can you try a quick patch and
 see if that fixes it?
 What is more worrying is that if I abort my regression tests part way
 through and check the postgis_reg database manually, the spatial_ref_sys
 table seems to be there...
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/395#comment:1>
