[postgis-devel] Implement "make astyle" patch
Nicklas Avén
nicklas.aven at jordogskog.no
Thu Jan 28 07:11:56 PST 2010
No, that's the thing, that it isn't astyle.exe that I'm using. I had to compile astyle and install it into some "linux"-directory because your script won't find the exe-file if it isn't in the actual folder (or in the path I guess)
/Nicklas
2010-01-28 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> Ok, I think that works
>> I replaced "astyle" with "tastyle" in both row 6 and 26, then it stoped
>> so I guess it works :-)
>> BTW, how to uninstall astyle for testing it properly. Now I had to cheat.
>> Do I then have to manually delete files, or?
>> /Nicklas
>Just rename astyle.exe to something else just before running "make astyle".
>HTH,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100128/73a3bb46/attachment.html>
