[postgis-devel] [PostGIS] #395: Make check errors on Mac - spheroid area - srid 32702
PostGIS trac at osgeo.org
Thu Jan 28 07:16:49 PST 2010
  Reporter:  colivier  |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  medium    |   Milestone:  PostGIS 1.5.0
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:  Mac regress  spheroid_area 32702
Comment (by colivier):
 Well that's not look 'that' simple, if i insert the 2 missing srid:
 Index: tickets.sql
 --- tickets.sql (revision 5172)
 +++ tickets.sql (working copy)
 @@ -6,6 +6,8 @@
  DELETE FROM spatial_ref_sys;
  INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32611,
 '+proj=utm +zone=11 +ellps=WGS84 +datum=WGS84 +units=m +no_defs' );
  INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 4326,
 '+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs' );
 +INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32602,
 '+proj=utm +zone=2 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
 +INSERT INTO spatial_ref_sys ( srid, proj4text ) VALUES ( 32702,
 '+proj=utm +zone=2 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs ' );
 Produce this new regress output (cunit fails are obviously still the
 same):
 *** tickets_expected    Thu Jan 28 14:54:28 2010
 --- /var/folders/lq/lq3l11tSFeyWgrx8TopGk++++TI/-Tmp-//test_47_out
 Thu Jan 28 16:14:40 2010
 *** 64,66 ****
 --- 64,76 ----
   #277|<gml:Point><gml:coordinates>1,1e+308</gml:coordinates></gml:Point>
   #299|2
   #304
 + POINT(-170 -80)|0.000115919886854499|0.00011467046914504
 + POINT(-170 -70)|5.82107245751251e-5|5.56136178916367e-5
 + POINT(-170 -60)|3.50390659657751e-5|3.50390659657751e-5
 + POINT(-170 -50)|2.41302911850039e-5|2.41302911850039e-5
 + POINT(-170 -40)|1.70080525747629e-5|1.70080525747629e-5
 + POINT(-170 -30)|1.17068806768372e-5|1.17068806768372e-5
 + POINT(-170 -20)|7.38417888529463e-6|7.38417888529463e-6
 + POINT(-170 -10)|3.57911220325025e-6|3.57911220325025e-6
 + POINT(-170 10)|3.58120134247297e-6|3.58120134247297e-6
 + POINT(-170 20)|7.38386138654512e-6|7.38386138654512e-6
Ticket URL: <http://trac.osgeo.org/postgis/ticket/395#comment:3>
