[postgis-devel] Implement "make astyle" patch
Nicklas Avén
nicklas.aven at jordogskog.no
Thu Jan 28 07:18:22 PST 2010
No, everything works fine but I am not using the exe-file, I'm using the linux installation As I understand it the alternative is to add my folder with source-code where I have the astyle.exe into PATH, but I see no reason. Isn't it better to run the "linux"-version? Everything works fine. I just wondered in general how to uninstall after make install. /Nicklas
2010-01-28 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> No, that's the thing, that it isn't astyle.exe that I'm using. I had to
>> compile astyle and install it into some "linux"-directory because your
>> script won't find the exe-file if it isn't in the actual folder (or in
>> the path I guess)
>> /Nicklas
>Right, the script expects to find astyle within PATH. That seems very
>reasonable to me. Perhaps you need to alter PATH on your MSYS
>installation to include /usr/local/bin?
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100128/4912784c/attachment.html>
