[postgis-devel] Testing astyle rule
Paul Ramsey
pramsey at cleverelephant.ca
Thu Jan 28 11:51:16 PST 2010
Mark, don't you find that you can run
astyle --style=ansi --indent=tab <list of files>
and have it both (a) not alter files that need to be altered and
(b) leave .orig files hanging around afterwards?
Your approach seems to be making a modification to the file metadata
at a minimum, (atime? mtime?) even when there's no content change.
P.
On Thu, Jan 28, 2010 at 11:47 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I'd say so... when I ran it here, I had about 1/2 coming out modified
> (which was still, to my mind, a little high, since I ran every file at
> the 1.4 release time)
> P
> On Thu, Jan 28, 2010 at 11:44 AM, strk <strk at keybit.net> wrote:
>> Just for testing, I fetched current trunk (r5177)
>> and run 'make astyle'.
>> Now, is the fact that *every* file results modified
>> a sign of something not working as expected ?
>> --strk;
>> () Free GIS & Flash consultant/developer
>> /\ http://foo.keybit.net/~strk/services.html
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
