[postgis-devel] Testing astyle rule
Kevin Neufeld
kneufeld at refractions.net
Thu Jan 28 12:47:58 PST 2010
It doesn't affect every file when I run it. It does affect quite a few (65 files to be exact) and all seem to be valid
style fixes. I don't get any .orig files and Paul's additional parameters doesn't seem to make any difference to the
modified files.
-- Kevin
On 1/28/2010 11:52 AM, Paul Ramsey wrote:
> astyle --style=ansi --indent=tab --suffix=none
> to avoid creating .orig files on modified files
> P
> On Thu, Jan 28, 2010 at 11:51 AM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
>> Mark, don't you find that you can run
>> astyle --style=ansi --indent=tab<list of files>
>> and have it both (a) not alter files that need to be altered and
>> (b) leave .orig files hanging around afterwards?
>> Your approach seems to be making a modification to the file metadata
>> at a minimum, (atime? mtime?) even when there's no content change.
>> P.
>> On Thu, Jan 28, 2010 at 11:47 AM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
>>> I'd say so... when I ran it here, I had about 1/2 coming out modified
>>> (which was still, to my mind, a little high, since I ran every file at
>>> the 1.4 release time)
>>> P
>>> On Thu, Jan 28, 2010 at 11:44 AM, strk<strk at keybit.net> wrote:
>>>> Just for testing, I fetched current trunk (r5177)
>>>> and run 'make astyle'.
>>>> Now, is the fact that *every* file results modified
>>>> a sign of something not working as expected ?
>>>> --strk;
>>>> () Free GIS& Flash consultant/developer
>>>> /\ http://foo.keybit.net/~strk/services.html
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
