[postgis-devel] [PostGIS] #549: ST_isCollection
trac at osgeo.org
Thu Jul 1 03:20:14 PDT 2010
Reporter: strk | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by yabo):
Something like this ?
There should also be a test on 'GEOMETRYCOLLECTION EMPTY' but I don't know
what it should return. Is an empty geometry a collection ? Maybe could the
C function be patched to catch that case.
$ svn diff
Index: iscollection_expected
--- iscollection_expected (revision 0)
+++ iscollection_expected (revision 0)
@@ -0,0 +1,11 @@
+f
+f
+f
+t
+t
+t
+t
+t
+t
+t
+t
Index: iscollection.sql
--- iscollection.sql (revision 0)
+++ iscollection.sql (revision 0)
@@ -0,0 +1,17 @@
+-- Ensure there are no false-positives
+SELECT ST_IsCollection('POINT(42 42)');
+SELECT ST_IsCollection('POLYGON((0 0, 10 0, 10 10, 0 10, 0 0))');
+SELECT ST_IsCollection('LINESTRING(0 0, 10 10)');
+--Ensure that all collections return true (even if they contain a single
geometry).
+SELECT ST_IsCollection('MULTIPOINT((0 0))');
+SELECT ST_IsCollection('MULTIPOINT((0 0), (42 42))');
+SELECT ST_IsCollection('MULTILINE((0 0, 10 10))');
+SELECT ST_IsCollection('MULTILINE((0 0, 10 10), (100 100, 142 142))');
+SELECT ST_IsCollection('MULTIPOLYGON(((0 0, 10 0, 10 10, 10 0, 0 0)))');
+SELECT ST_IsCollection('MULTIPOLYGON(((0 0, 10 0, 10 10, 10 0, 0 0), (100
100, 110 100, 110 110, 100 110, 100 100)))');
+SELECT ST_IsCollection('GEOMETRYCOLLECTION(POINT(0 0))');
+SELECT ST_IsCollection('GEOMETRYCOLLECTION(POINT(0 0), POINT(42 42))');
Ticket URL: <http://trac.osgeo.org/postgis/ticket/549#comment:4>
