[postgis-devel] GUI Speed
Paul Ramsey
pramsey at opengeo.org
Mon Jul 12 12:04:30 PDT 2010
Or, maybe I'm just an idjit. I just re-ran the tests and the gui and
cli do the load in very nearly the same amount of time. And the
profiles look nearly identical. Not sure what effect I was observing
last week. Sorry for the chatter.
P.
On Mon, Jul 12, 2010 at 7:45 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> Mark,
>> The main point in the profile, is that the majority of time is not
>> being spent in the loader at all, it's being spent in the postgres
>> process. And oddly, the gui and the cli are exercising very
>> *different* parts of the postgres code.
>> P.
> No worries, I understand that part. My point was more that while we can see
> that the postgres process is taking more time, we cannot determine whether
> or not that is because it is waiting for lines of data (i.e. it's taking
> much longer for each line of data to reach the server).
> Re-reading the API docs, it does seem that PQputCopyData() can handle any
> specific buffer size of data. So if you think PQputCopyData() is the
> bottleneck, try picking a buffer of around 64k, strncat multiple lines
> together within the main loop until the buffer is full, and then send
> everything as a massive buffer-sized chunk in one go.
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
