[postgis-devel] [WKT-Raster] rtpostgis.dll not founded
André Silveira
andrecarvalhosilveira at gmail.com
Wed Jul 21 12:48:12 PDT 2010
You are right!
It is working now!
My suggestion is modify the README.TXT orienting the copy of libgdal.dll
file before the running of rtpostgis.sql
I just copy the libgdal.dll to
'C:\Program Files\PostgreSQL\8.4\lib'
and
'C:\Program Files\PostgreSQL\8.4\bin'
I guess that just the lib directory is enough.
Thanks so much,
André Silveira
2010/7/21 Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> Do you have libgdal.dll somewhere? rtpostgis.dll is dependent on this
> dll.
> Pierre
> *From:* postgis-devel-bounces at postgis.refractions.net [mailto:
> postgis-devel-bounces at postgis.refractions.net] *On Behalf Of *André
> Silveira
> *Sent:* 21 juillet 2010 12:59
> *To:* postgis-devel at postgis.refractions.net
> *Subject:* [postgis-devel] [WKT-Raster] rtpostgis.dll not founded
> Hi,
> I have problems to install the WKT-Raster extension on my spatial DB and
> after check the discussions about this topic I still have the error not
> solved.
> If it is possible a little help I am thanks.
> I am installing the WKT-Raster over PostGIS 1.4 and PostgreSQL 8.4 in a
> Windows Vista and when I run the rtpostgis.sql the pgAdminIII alert that
> can not load library "C:/Program Files/PostgreSQL/8.4/lib/rtpostgis.dll":
> unknown error 126
> SQL state: 58P01
> I have setted the environment variable PATH to 'C:\Program
> Files\PostgreSQL\8.4\lib' and the file rtpostgis.dll is in this directory.
> I have checked the related thread of Steve and Jorge Arévalo, but in my
> case the error persists.
> Thanks for your attention,
> André Silveira
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100721/7596176e/attachment.html>
