[postgis-devel] How to look for spatial index for raster
Paragon Corporation lr at pcorp.us
Sun Jul 25 13:46:39 PDT 2010
Mat,
> Folks,
> What is the recommended query against the PostgreSQL catalog
> to find if spatial index is available for WKT Rater table/column?
> I imagine checking for gist_geometry_ops does not work for rasters, does
it?
 WKT Raster just uses a spatial index around the ST_Envelope geometry  of
the raster.
So the below queries should tell you which raster columns have spatial
indexes and which don't.
-- find out which raster columns are missing geometry index
SELECT c.table_schema, c.table_name, c.column_name
FROM (SELECT * FROM
	information_schema.tables WHERE table_type = 'BASE TABLE') As t
INNER JOIN
	(SELECT * FROM information_schema.columns WHERE udt_name = 'raster')
c
		ON (t.table_name = c.table_name AND t.table_schema =
c.table_schema)
		LEFT JOIN pg_catalog.pg_indexes i ON
			(i.tablename = c.table_name AND i.schemaname =
c.table_schema
				AND  indexdef LIKE '%' || c.column_name ||
WHERE i.tablename IS NULL
ORDER BY c.table_schema, c.table_name;
-- which raster columns have spatial index
FROM (SELECT * FROM
INNER JOIN
c
c.table_schema)
c.table_schema
WHERE i.tablename IS NOT NULL
Hope that helps,
Regina
http://www.postgis.us
